E50 polini tm24 jetting and plug
Luke Stroehlein /
Hi all, I have a polini project going and am trying to prevent seizing before I run it for the first time. I have the intake ports opened up a little, 4 petal dio knockoff, 24mm intake, hpi mini internal rotor, case matched, mlm Cali side bleed. What jetting would you recommend? Also wondering if you have a recommendation on the best plug heat to use. Thanks!
Re: E50 polini tm24 jetting and plug
Dirty30 Dillon /
Why is your crank case tapped for vacuum?
Luke Stroehlein /
Running a fuel pump, also mikuni, 14lph
Dirty30 Dillon /
Interesting. Seems like overkill unless you for some reason can't run gravity feed due to tank location.
Luke Stroehlein /
I'm building a kinda overkill bike, trying to push the envelope
Overpriced Parts /
Fuel pump is great for a tm24 cause because unless you have the float so high that it almost leaks out of the overflow you’ll be for fuel starved at hi p.m.
For a polini that the intake on the cylinder boost ports opened up a bit start at around 190 jet and work down should be good, stock without the intake opened up on boost ports the tm 24 carb may too big, 8# ngk plug
Luke Stroehlein /
Awesome thank you! I need to check what jet I have in there, I know I changed it out but it's been a few years that I've left this project sitting. The ports are definitely opened up. I've seen some people here running 200 or even as much as 220 on a polini. 190 isnt gonna be too lean in your opinion? And 8 spark plug, got it!
190 should more than likely be too rich. What pipe? Probaly more around the range of 155-160.
Luke Stroehlein /
Mlm Cali pipe, she's a fatty that's it hanging on the frame during a mock up
B8HS is a good plug. Jetting around 170 BUT you have to be certain that you don't have any air leaks. Best way to check is a leakdown test.
What did you gap your ring to?
Have you tried doing a piston drop test (with the intake bolted on but no piston ring) to see if it's rubbing on the cylinder anywhere? Check out this thread:
https://www.mopedarmy.com/forums/read.php?7,2681917
Here's a good writeup for the polini:
https://magnumdash.wordpress.com/2010/03/18/guide-pro-tips-to-building-a-puch-polini/
Overpriced Parts /
The drop test is totally different if you have the cylinder bolted to the case first, That’s the way I’ve always done it and it’s way different,
I bolt The head, cylinder, piston and everything on then I attach the intake to the cylinder it’slike night and day, the drop test that pulls up on the cylinder on intake side making the piston drag a bit is almost nil.
Dirty30 Dillon /
How do you drop a Piston through the motor to test if the cylinder and head are bolted to the case?
I think he means that he assembles the motor and then drops it on the floor, a durability test of sorts
Luke Stroehlein /
Well I dropped the entire engine on the ground as suggested and now it's cracked, thanks guys... But in all seriousness thanks for some of the suggestions, I'm gonna do a little more tweaking and testing before I run it. Bought 2 BR8HS plugs today, one for the engine and one spare.
Insert facepalm pictures
