Up-jetting a clean 1979 Vespa Ciao
Please tell me about the time you upgraded the jet on your Vespa Ciao. I'm having trouble figuring this out. I read the wiki, but I'm a beginner. It didn't help much.
my moped was stock until the previous owner put on a Dellorto 13.13 and a Malossi high flow air filter. He also put in a new spark plug. It's about a year old and has less than 100 miles on it. I don't know if he enlarged the intake. I will need to measure.
I just installed a Giannelli Fire Circuit Pipe.
Sucker is still slow. Tops out at 20-23. No improvement since upgrading the pipe.
The jet is size 55. I don't know if it is original or if it was an upgrade from the original.
I'm going to try up-jetting. Should I get a full range of Dellorto 56-65? I don't know how this works. On treatland it says I can order 50s range odd, or 50s range even, and so on. Should I buy a bunch in 50s and 60s?
If up-jetting doesn't get me to 35mph, then I will try the next thing, whatever that is.
thanks!
Re: Up-jetting a clean 1979 Vespa Ciao
Start with a 62 and go from there. You are probably very lean
Run a toothed belt and make sure it is tight
What Alex said. Also, it never hurts for a mopeder to have some extra jets. Order a range and be ready for when your bud needs one.
