Morini MO2 Intake
I have a Malaguti commuter with the MO2 and 12 mm OD intake. Does anyone know where I could get a larger intake to maximize the dellorto 14.12?
Re: Morini MO2 Intake
I’ve drilled and filed quite a few intakes just be careful not too deep
Dirty30 Dillon /
You are maximized, the 14.12 only has a 12mm Venturi.
The OD on the intake is 12mm so wouldn't my max ID be 12mm? I didn't know if there were any Morini intakes with 12mm IDs...
Hmm , last I heard , 12 from 12 is 0 .
I'm well aware of that. I figured that they might make an intake that had a 14mm od and 12mm ID. Stock is 12/10.
Did you actually measure the id of your intake? Most Morini intakes say 12mm but the I'd is really 8mm. I would suggest measuring with a micrometer first
Yeah I can measure it tomorrow.
ID is 8mm stock. I'll try boring out to 10 and see what that does to my performance
Make it all match up !
I’m going to ask my cousin if he can make a mini reed valve out of the spacer plate with his 3D printer so I can go BIG on the intake
Sorry , double post . :((edited)
Figure what the are of the hole in the cylinder is .
That's as big as you'll need to go with any intake .
Anything over that amount will be wasted , unless you'll be hogging that cylinder hole out . Then figure what area that might end up being ...
