Crank for a vespa reed valve case half
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
https://www.treatland.tv/vespa-pinasco-dual-carburetor-case-half-43mm-p/vespa-pinasco-dual-carb-43mm.htm Does this require a special crank? I know it links to one but would it run with a mazzulcheti antipatico crank?
Re: Crank for a vespa reed valve case half
Dirty30 Dillon /
If you are running that case half you need to have the crank with the hole through the pin. Otherwise you're only pulling mixture through the spinning bearing race.
Dang then this isn't the case for me.
Dirty30 Dillon /
Sounds like you're looking for this .
You'll most likely have to do some subframe/frame mods to make it work either way.
