78 Maxi full build
Trevor McGrath /
Hello everyone!!
New to the vintage world of mopeds
Starting my full 78 maxi/cafe/bobber build
Everything has been ordered, soon as it arrives i will be taking step by step photos of all assembly and any modifications done while the build is underway!!
Any input, tricks, guidance would be cool, have tons of mechanical and some fabrication knowledge, tools available are just about any and all, (own my own shop)
if anyone has any other input or ideas for my build, i welcome all comments!!!
motor is a single speed e50
70cc ultimate treat kit
70cc hi hi head
45mm reed valve kit
vm20 mikuni carb
Radical sidebleed estoril pipe
super stuffy crank
cdi conversion kit
ebr front forks
Mlm rear swingarm
treatmetric jammer clutch version 6.4
gp1 street performance tires
grimeca 17" snowflake wheels
slammed puch black solo seat
Mlm shortened seat post
Black street low rise bars
Gsx gold drive chain
og deluxe magura throttle assembly
black brake lever kit
mikuni jet pack (10)
im sure im missing small stuff but long story short for an intro is everything is on the way and i couldnt be more excited !! Planning on jamming on this all summer so praying everything works out!!!
working on uploading photos of the maxi being stripped down !!
Re: 78 Maxi full build
Sounds like a lineup for a good project.
Trevor McGrath /
Thank you, took some time selecting the parts, from what i can tell it should move my 160lb ass decently lol
Good luck! But you are gonna regret those low bars.
up shits creek /
i've ridden on low bars. not very comfy. much prefer high/stock bars
Trevor McGrath /
do you have any pictures of them mounted?
Trevor McGrath /
do you by chance have any pictures or another set you would recommend?(edited)
I’ve ridden a maxi for years with the long seat slammed all the way down and bars like you have listed.
It was comfortable for me and I’m 5’11” and 200lbs. I was having too much fun to notice if it ever got uncomfortable. Even on hour long rides.
Just do it if you like the looks and if you don’t like how it rides later, change it.
Leaning forward on the bars is good for weight distribution and control.
Old pic. But you can see the shape of things.
If you're doing a top down rebuild then you should consider replacing brake shoes (depending on wear), rebuilding and greasing the brake plates, and repacking and re-greasing the wheel bearings (or better yet switch to sealed bearing axle conversion, especially for the rear wheel at least)
Trevor McGrath /
thank you! yes forgot to mention new shoes, tires tubes and i also am currently working on the wheel hub, just a clean, and repack before i mount my new tires on them !
Trevor McGrath /
Update
got the e50 completely stripped and ready to be case matched!
Luke Stroehlein /
Good luck, I'm excited to see this unfold
