TOMOS Revival A35, exhaust upgrade Recommendation needed.
Hello People, I'm completely new to mopeds, recently got a TOMOs revival with an A35, which I upgraded to a 70 cc. now I got a really nice pipe from treatland, and they were not able to tell me if it was going to fit properly. As a result it did not fit the frame, and im having to return the item. thus, the reason of this post, to find if any of you all in the community would be able to help me find something that would be better than the old stock pipe it has. Im looking for something that does not has to be moddified to fit the frame. however, any other recommendation is also welcome.
Thanks!!
Pepa
Re: TOMOS Revival A35, exhaust upgrade Recommendation needed.
I think for a pipe to fit you have to cut off one of those sissy bar supports. If the pipe you have has the thick bracket and is close then just heat the header with a torch and bend.
I used this pipe on my fully dressed revival and it fit perfect. https://www.treatland.tv/tomos-A55-tecno-bullet-pipe-chrome-baffle-p/tomos-a55-tecno-bullet-20017.htm
That is all
Amazing!! Thanks you both, these is very helpful info!. Was not expecting such a fast answer! Will see if they have that same pipe for my a35. Thanks so much again!
Ahh Ofcourse! So, that was a mid year that used a55 mounts on a a35. Use this pipe here https://www.treatland.tv/tomos-A35-tecno-bullet-p/tomos-tecno-bullet-a35-alu.htm and this bracket https://www.treatland.tv/tomos-A3-A35-exhaust-bracket-p/tomos-exhaust-bracket-a35.htm will mount and clear the pedals! Might have to do a little drilling on one of the holes but I just checked and it is almost perfect!!
With moped aftermarket pipes I never expect a perfect mount. As long as the flange at the header connects nicely with the cylinder and doesnt put the pipe and some dumb angle, I will make a mounting bracket that works. If you have to, you could always bend out a pedal arm a bit for pipe clearance.
