Gila base gaskets
I came across some base gaskets that Treatland sells.
https://www.treatland.tv/MLM-puch-metal-base-plate-spacer-for-p/mlm-puch-metal-plate-oversize.htm
They come in different thicknesses, and you can stack a combination of them to "create a perfecto squish".
My question is, how do you determine what thickness gasket you need?
Re: Gila base gaskets
Wesley Ambrosini /
When the piston clears the exhaust port at bdc
Look up how to do it. Lots of info out there put a piece of soddder in the it will squish then measure the squished part. Done ✅ that is how you get your squash right.
If anyone knows of any good tutorials or videos, plz post links... I'm not finding much.
https://www.mopedarmy.com/forums/read.php?7,4173119
Did you watch here? First Link was this
Here's a couple videos I found helpful:
Anyone know what the acceptable range of the squish should be? I read between .6-.8mm.
please correct if i'm wrong, but wouldnt you want to clear the exhaust port with the edge of the piston before worrying about/measuring squish?
Squish should be altered with the head/head gasket, not the base gasket, right?
Also, the base gasket will shrink when compressed..not a lot, but enough to double check your clearances after heating/torquing.
Matt Mahloch -- MBM Customs /
You want your exhaust and transfers to open fully. Use that spacer to adjust. Adjust your squish from the top.
