Vespa Malossi clutch bell issues
Chris Carleton /
Anyone got one? Problems? Installed mine and it won't turn when nut is tight? Looks like some interference .
Re: Vespa Malossi clutch bell issues
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
do you have that spacer on the back? also check that the engine is square with the frame
Dirty30 Dillon /
The malossi bell is not perfect. I think the length of the shaft mounting portion is a little long and needs to be filed down a bit.
If it's binding when tightened, it means the bell is either pulling against the the clutch assy itself, or you've pinched the starter shoes in there.
or its rubbing on the frame
Dirty30 Dillon /
Clutch bell doesn't come anywhere near the frame.
Ooooh thought this was for a single speed
Are these much lighter than stock, or just stronger?
Dirty30 Dillon /
They're quite a bit lighter than stock, and much stronger. I'll be grabbing a few of these once I can get a handle on some stock
On my cnc bell from treats with the euro clutch the stater clutch bell was rubbing against the clutch bell causing it not to spin when tightened down.
Here’s the weight difference from stock to the malossi from Vespa-ciao.nl
Chris Carleton /
Solved with a thin machine washer yup a euro clutch.
Dirty30 Dillon /
Good news.
