Re: I need a dellorto sha guru!
classic carl jepsen /
When you take the lid off it has a lower air pressure so it will burn easier. How much smoke are you getting on startup. Fuel is a huge factor with these things. If I mix to much oil in with the gas I have a lot of problems starting it. Or if you put gas in by mistake it won't burn very good. First thing to try is drain the tank into a can and put fresh gas in it and try again. Second thing is cjack you air bleed screw on the back. If your moped is barely running turn the screw clockwise until flames start coming. When the cone starts glowing back screw off until the flames aren't coming around the cone anymore and that should be about optimum setting.
  I need a dellorto sha guru!Topic by: Rob P Rob P 06/24/20 11:40PM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 06/24/20 11:46PM
  Re: I need a dellorto sha guru!Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 06/24/20 11:46PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 06/25/20 12:33AM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 06/25/20 09:22AM
  Re: I need a dellorto sha guru!Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 06/25/20 12:37AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 06/25/20 12:58AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 06/25/20 01:08AM
  Re: I need a dellorto sha guru!Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 06/25/20 01:19AM
  Re: I need a dellorto sha guru!Re: Born to be WillD Born to be WillD 06/25/20 05:02AM
  Re: I need a dellorto sha guru!Re: Born to be WillD Born to be WillD 06/25/20 01:16AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 06/25/20 01:25AM
  Re: I need a dellorto sha guru!Re: pat splat pat splat 06/25/20 08:26AM
  Re: I need a dellorto sha guru!Re: Born to be WillD Born to be WillD 06/26/20 12:38AM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 06/26/20 09:25AM
  Re: I need a dellorto sha guru!Re: Shane Macpherson Shane Macpherson 08/29/20 02:54AM
  Re: I need a dellorto sha guru!Re: kenny s kenny s 06/25/20 02:54AM
  Re: I need a dellorto sha guru!Re: Aaron Blair Aaron Blair 06/25/20 06:00AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 06/25/20 05:01PM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 06/25/20 05:14PM
  Re: I need a dellorto sha guru!Re: Mike Boyd Mike Boyd 06/25/20 06:25PM
  Re: I need a dellorto sha guru!Re: baird co baird co 06/25/20 07:44PM
  Re: I need a dellorto sha guru!Re: Satan 666 Satan 666 06/25/20 09:36PM
  Re: I need a dellorto sha guru!Re: pat splat pat splat 06/25/20 09:49PM
  Re: I need a dellorto sha guru!Re: Jay Rivett Jay Rivett 06/26/20 08:48AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 07/08/20 01:03PM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 07/08/20 02:07PM
  Re: I need a dellorto sha guru!Re: Mike Boyd Mike Boyd 07/08/20 03:18PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 07/13/20 10:56AM
  Re: I need a dellorto sha guru!Re: Seth B Seth B 07/13/20 11:34AM
  Re: I need a dellorto sha guru!Re: Jay Rivett Jay Rivett 07/08/20 04:08PM
  Re: I need a dellorto sha guru!Re: ♣Slew Foot♣ ♣Slew Foot♣ 07/12/20 09:03AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/03/20 09:56AM
  Re: I need a dellorto sha guru!Re: todd amundson todd amundson 07/13/20 12:18PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/03/20 10:00AM
  Re: I need a dellorto sha guru!Re: Jay Rivett Jay Rivett 07/13/20 01:25PM
  Re: I need a dellorto sha guru!Re: Cameron Cate Cameron Cate 07/14/20 07:13PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/03/20 09:41AM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 08/03/20 10:07AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/25/20 11:26AM
  Re: I need a dellorto sha guru!Re: Jay Rivett Jay Rivett 08/25/20 12:27PM
  Re: I need a dellorto sha guru!Re: LSLB RXb LSLB RXb 08/25/20 02:51PM
  Re: I need a dellorto sha guru!Re: P D P D 08/25/20 04:04PM
  Re: I need a dellorto sha guru!Re: LSLB RXb LSLB RXb 08/25/20 04:18PM
  Re: I need a dellorto sha guru!Re: P D P D 08/25/20 05:11PM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 08/26/20 07:48AM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 08/26/20 08:14AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/29/20 04:36PM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 08/29/20 09:12PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/29/20 04:42PM
  Re: I need a dellorto sha guru!Re: Jay Rivett Jay Rivett 08/29/20 09:03PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 08/31/20 01:36PM
  Re: I need a dellorto sha guru!Re: Dirty30 Dillon Dirty30 Dillon 08/31/20 02:09PM
  Re: I need a dellorto sha guru!Re: Jay Rivett Jay Rivett 08/31/20 03:44PM
  Re: I need a dellorto sha guru!Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 09/02/20 09:14AM
  Re: I need a dellorto sha guru!Re: pat splat pat splat 08/31/20 09:20PM
  Re: I need a dellorto sha guru!Re: Jesse Stephenson Jesse Stephenson 09/01/20 06:34PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 11/07/20 10:16PM
  Re: I need a dellorto sha guru!Re: Tweaker trash Tweaker trash 01/24/21 09:25PM
  Re: I need a dellorto sha guru!Re: baird co baird co 11/08/20 12:36AM
  Re: I need a dellorto sha guru!Re: Trent Anderson Trent Anderson 11/09/20 12:06AM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 11/13/20 11:35PM
  Re: I need a dellorto sha guru!Re: ♣Slew Foot♣ ♣Slew Foot♣ 01/24/21 07:30PM
  Re: I need a dellorto sha guru!Re: classic carl jepsen classic carl jepsen 11/18/20 07:23PM
  Re: I need a dellorto sha guru!Re: Dallas Burgles Dallas Burgles 11/19/20 10:02AM
  Re: I need a dellorto sha guru!Re: baird co baird co 11/19/20 12:27PM
  Re: I need a dellorto sha guru!Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/19/20 04:26PM
  Re: I need a dellorto sha guru!Re: P D P D 11/19/20 04:59PM
  Re: I need a dellorto sha guru!Re: Rob P Rob P 01/04/21 12:56PM
