Simson 50cc high end porting
Kilian Münscher /
I am going to port a 50cc stock cylinder that should in the end produce somewhere between 11hp and 16hp.
I am going to cut in 3 more ports to the existing ones and try to match the new ports to the aprilia rs125 design.
And of course to get a fitting amount of blow down time area I will cut auxiliary exaust ports and raise the exaust port timing to about 178 to 184 degrees, because I still want to have a wide powerband to fit the 3 gear engine I have.
I am going to use a reed intake system now here I am starting to get problems, as I never have worked with reeds before (only with piston ported an rotary valve engines) I don't know what reed I should use.
I am thinking of a 28mm carburetor.
Should I use a malossi reed?
V force would be nice but I think they are to expensive for me.
Any suggestions?
Thanks
  Simson 50cc high end portingTopic by: Kilian Münscher Kilian Münscher 08/12/20 03:03PM
  Re: Simson 50cc high end portingRe: Born to be WillD Born to be WillD 08/13/20 03:30PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 03:59AM
  Re: Simson 50cc high end portingRe: Born to be WillD Born to be WillD 08/14/20 11:58AM
  Re: Simson 50cc high end portingRe: Dave & Bummerzz Dave & Bummerzz 08/14/20 11:13AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 01:04PM
  Re: Simson 50cc high end portingRe: Dickie Thompson Dickie Thompson 08/14/20 01:46PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 01:55PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 01:57PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 02:44PM
  Re: Simson 50cc high end portingRe: JBOT Admin JBOT Admin 08/14/20 03:08PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 03:12PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/14/20 03:24PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/18/20 02:04PM
  Re: Simson 50cc high end portingRe: Sander Mulder Sander Mulder 08/18/20 04:09PM
  Re: Simson 50cc high end portingRe: JBOT Admin JBOT Admin 08/18/20 02:56PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/18/20 03:44PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/19/20 04:02AM
  Re: Simson 50cc high end portingRe: JBOT Admin JBOT Admin 08/19/20 02:34PM
  Re: Simson 50cc high end portingRe: Dickie Thompson Dickie Thompson 08/20/20 02:42PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/19/20 05:23AM
  Re: Simson 50cc high end portingRe: Jay Rivett Jay Rivett 08/19/20 08:55AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/19/20 09:34AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/19/20 02:51PM
  Re: Simson 50cc high end portingRe: JBOT Admin JBOT Admin 08/20/20 12:39AM
  Re: Simson 50cc high end portingRe: Jay Rivett Jay Rivett 08/19/20 03:57PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/19/20 04:05PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/20/20 02:46AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/20/20 02:51PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/26/20 07:09AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/27/20 08:21AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/31/20 04:33AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 08/31/20 04:11PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/04/20 02:21AM
  Re: Simson 50cc high end portingRe: P D P D 09/04/20 07:41AM
  Re: Simson 50cc high end portingRe: Ryan Graeme Ryan Graeme 09/05/20 03:25AM
  Re: Simson 50cc high end portingRe: Sander Mulder Sander Mulder 09/05/20 03:31AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/05/20 03:59AM
  Re: Simson 50cc high end portingRe: Jay Rivett Jay Rivett 09/06/20 11:36AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/06/20 02:06PM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/07/20 06:20AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/07/20 09:53AM
  Re: Simson 50cc high end portingRe: Dirty30 Dillon Dirty30 Dillon 09/07/20 10:29AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/09/20 10:54AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/09/20 11:02AM
  Re: Simson 50cc high end portingRe: Kilian Münscher Kilian Münscher 09/12/20 07:20AM
