You’re starting from a disadvantage using a stock cyl, but if you add a ton of material to the cyl and add rotary intake it’s totally doable and would be better than reed if you do it right. Lots of hurdles to jump over tho
Only limit is your skills with fuckery.
I like doing things like this too.
Making something into something totally different with only your will. Good luck
