Re: Puch maxi Track toy
Pablo Puchasso /
Whoa these clutch covers are esp. cool. Great thread A+ stuff... I'm hopeful someone will do a clear clutch cover like the Simson guys have been doing.
Sander Mulder /
I have made a extended clutch cover once, but the capacity is probably much as a kickstart cluth cover, so in my opinion, not worth it if you dont use the run-start
Clear covers.., if someone knows what plastic or glas i need to use, i want to make one (edited)
and im over here like...
@potr
Lmao! I know right?
Sander Mulder /
now i need some extra spare time to make this lol (edited)
Just print out the 2 pieces and insert a round of bullet proof glass . It could be done over night . ;)
Sander Mulder /
nah, i dont trust 3d printed parts when it gets in contact with hot oil ;)
Maybe use a better material ?
See through so you can watch your clutch explode in real time lol
Sander Mulder /
yess, fun, isn't it? , but serieus, i dont think theyre going to allow this on track, if something fails inside, oil is all over the track :(
Sander Mulder /
> oil
like what?, dont know the exact oil temperature, we are using 500ml oil instead of 200, so you dont cook your oil.
Maybe one of these ?
https://www.imakr.com/chemical-resistant-3d-filaments
I'm not into printing , so ???
Kilian Münscher /
Do you have a cnc mill?
How do you keep your oil from coming out of the top vent hole on the e50? Whenever my oil gets hot it starts coming up out of the vent hole, and that is with close to the stock amount of oil.
Just make those port hole windows available for us to buy once you figure it all out.
Sander Mulder /
unfortunatly not, if i want something cnc milled i can do that at school or by a friend of my.
Sander Mulder /
> figure it all out.
we use catch cans, so drill the vent hole, put some thread in there, with a hose to the catch can.
Yeah you don’t even have to tap it really, I was having this problem at the track so I just drilled it out and shoved some 3/16 fuel line in and ran the hose up under my seat, no more problems.
Both excellent ideas, I will look into it as it would be nice to run a little extra oil. Is there no concern about pressure building up inside the cases if the vent is then closed up in the catch system? Sorry Sander not trying to thread jack.
Has to be open otherwise it will blow oil out the seals. (edited)
Kilian Münscher /
will you built the frame completely from scratch or will this be a modified puch frame.
Sander Mulder /
Sander Mulder /
Current is a modified maxi chassis, if i build a next one, its going to be a pinto/x30
