Whoa these clutch covers are esp. cool. Great thread A+ stuff... I'm hopeful someone will do a clear clutch cover like the Simson guys have been doing.
Re: Puch maxi Track toy
I have made a extended clutch cover once, but the capacity is probably much as a kickstart cluth cover, so in my opinion, not worth it if you dont use the run-start
Clear covers.., if someone knows what plastic or glas i need to use, i want to make one (edited)
@potr
Lmao! I know right?
> Sander Mulder Wrote:
> now i need some extra spare time to make this lol
Just print out the 2 pieces and insert a round of bullet proof glass . It could be done over night . ;)
nah, i dont trust 3d printed parts when it gets in contact with hot oil ;)
Maybe use a better material ?
See through so you can watch your clutch explode in real time lol
yess, fun, isn't it? , but serieus, i dont think theyre going to allow this on track, if something fails inside, oil is all over the track :(
> oil
like what?, dont know the exact oil temperature, we are using 500ml oil instead of 200, so you dont cook your oil.
Maybe one of these ?
https://www.imakr.com/chemical-resistant-3d-filaments
I'm not into printing , so ???
Do you have a cnc mill?
How do you keep your oil from coming out of the top vent hole on the e50? Whenever my oil gets hot it starts coming up out of the vent hole, and that is with close to the stock amount of oil.
Just make those port hole windows available for us to buy once you figure it all out.
unfortunatly not, if i want something cnc milled i can do that at school or by a friend of my.
> figure it all out.
we use catch cans, so drill the vent hole, put some thread in there, with a hose to the catch can.
Yeah you don’t even have to tap it really, I was having this problem at the track so I just drilled it out and shoved some 3/16 fuel line in and ran the hose up under my seat, no more problems.
Both excellent ideas, I will look into it as it would be nice to run a little extra oil. Is there no concern about pressure building up inside the cases if the vent is then closed up in the catch system? Sorry Sander not trying to thread jack.
Has to be open otherwise it will blow oil out the seals. (edited)
will you built the frame completely from scratch or will this be a modified puch frame.
Current is a modified maxi chassis, if i build a next one, its going to be a pinto/x30
That looks really nice
What suspension on the front. Are you using. I am not sure how that is called
But why not built the frame yourself so it better suits your demands if you built the new frame. If you dont have a bender you can get nice results with taking tube then cutting slots in the inside of the place were you want to bent. And the bending and welding it.
At the moment i use a Honda MB fork, but i’m going to try a pitbike fork. Why i dont use a handmade frame?, rules ;). For the moped races i can only use original puch frames
Ahhh right i didnt tink about the rules.
I want that swingarm.. what is it off of?
