Re: Puch maxi Track toy
Sander Mulder /
> MPB Dylan Wrote:
> I made a custom swing arm for my Puch jawa ultra sport
Thats looking good! Mine is also a handmade swing arm.
Thanks! Mine is actually a subframe so I could bolt it on any tube frame bike with some welding, I would move the mounts if I was going to make another one
Sander Mulder /
polished the pipe, cant wait to start the engine.
Yeah we want video of this thing ripping.
Sander Mulder /
Wow... I think they look good
Sander Mulder /
First start today, needs some tuning but everything sounds good so far.
That thing sounds like a beast! Thanks for the video! Have fun!
Sander Mulder /
runs better now, time to put on a chain :)
Sander Mulder /
Not bad for a 60cc, almost 15000 (!) rpm.
Sounds fairly healthy . ;)
I just pooped a little. Sounds amazing. Have fun racing it. Thank you for sharing your build!
Rick Bergsma /
My wife wants me to ask you if that's Klaaskloosterweg you're blasting down
Sander Mulder /
> down
Haha, yes it is ;)
Sander Mulder /
This build isn’t over yet, still a long way to go
I’m planning to make a second engine.
And next week I get my Koso DB02R tachometer
https://www.koso.com.tw/products-detail.php?lang=en&id=294
Rick Bergsma /
> > down
> Haha, yes it is ;)
That's awesome , that's the street she grew up on
Kilian Münscher /
What are you thinking the 2nd engine is gonna be?
What kind of cylinder?
Carb?
Very nice build
Sander Mulder /
Probably a ‘normal’ 70cc puch cylinder because of the rules
Sander Mulder /
New dash arived, looks good to me!
Sander Mulder /
Small update,
First, my re-sleeved cylinder can't do competitions, because the sleeve, not allowed. So i have to build another 12hp+ engine. I still can use my resleeved engine for traning days.
So, for the new engine, a fresh milled pair of reed cases.
New cylinder will be ready in a few weeks.
Better disc brake, Galfer 260mm, 4 piston caliper. Have to make a custom adapter to fit the caliper.
Sander Mulder /
And... I'm going to another style. lighter, better handling, less damage when i crash.
fairings are getting painted (black, orange stickers) (edited)
Looking good!
Sander Mulder /
bought sick forks for my second racer. Going to be full WP suspension
Where do you purchase these from. Do they have the longer magnum length ones?
This is a great way to replace the front forks without replacing the whole triple tree which I can not actually remove from my bike.
Beside swingarm did you maybe make a axle too? If so what material you use for it?
Sander Mulder /
Unfortunatly i have to make a custom Triple tree set. Those forks are 51mm on top side. Length about 730mm
Sander Mulder /
And yes, we make our own axles. Material is 42CrMo4. I think thats normal steel for axles
You heat treat axles after production? If not secret what method? To what hardness?
Sander Mulder /
No secrets or hardening at all, never had problems with them
Sander Mulder /
https://toronda.com/product/cilinder-puch-maxi-e50-high-end-race/
Fastest puch cylinder you can buy, 18hp possible, straight out of the box
Only 70cc/45mm piston
Good work here in Holland
Man for 650 it better take you to the moon! Too bad they dont give you a peek at the ports.
