Re: Hobbit.... and we're off!
#1, don’t hijack threads.
#2, you’re running 6 x 6 gram rollers? Lol
Wayyyyyyyyyyy too heavy
Lighten your shit up a ton dawg
> Moped Newbie Wrote:
> I am having some issues with a Start V and bogging. My initial
> inclination was carb mistuning but after reading this, I am thinking it
> could be a variation issue. This is my first variated bike.
> Start V with 65 cc metrakit, TM24 (15 idle jet, 165 main jet, middle
> needle position, 5n13 needle) 6 gram weights, 16/33 gearing, removed
> starter clutch, stock contra and variator. Rk replica huge moped pipe w/
> black baffle. Malossi reeds. Timing 1.8mm. No air leaks with leak down
> test.
> The bike idles and revs without on the stand without issues. The bike is
> 4 stroking with acceleration - a lot at 1/2 to WOT and less frequently
> at WOT. The bike accelerates decently until 1/2 throttle then there is a
> lot of hesitation and losing of power and spitting gas.
> I have tried leaning the main down to 115 and needle position but this
> makes the bike run worst and there is still a lot of 4 stroking in the
> mid range. The plug looks to be on the richer side but not bad. The head
> temps hang around high 200s. Leaning up the main jet did improve the
> spitting of gas.
> How can I tell if it is carb tuning or variator tuning?
Alex Hedrick /
> it
> w/
> > test.
> is
> a
> head
> > spitting of gas.
Listen to jbot... unlike me.. lol but yeah, make a thread on the subject or whatever and you'll get all the help you'll need!
Like he said. Lighten that shit up!
In fairness, that’s not a gy6 pulley.
It’s a real Honda pulley so maybe you’ll be ok.
The China gy6 pulleys are garbage and what everyone has used, but if this is actually a Honda pulley it might be fine. No one has tested this with a real Honda unit. I used a real Yamaha 2t pulley and it was better, but I didn’t have a 3rd bearing so it was fucked with vibration at full variation
Honda>Chinese slave labor (edited)
Alex Hedrick /
Might be! Some website had it and got it to me the next day, it doesn't seem cheap quality wise.. other than the wobble is came with.. but I agree, I might have a fighting chance!
Oh wait I thought it was from a Ruckus?
If you’re not sure it is oem made by Honda I will just assume it’s china and garbage (edited)
Alex Hedrick /
> and garbage
Yeah I didn't pull it from a ruckus..
It more than likely is Chineseium! I still plan to get an oem pulley and actually machine the shaft adapter. I just jumped the gun lastnight and kinda wanted a proof of concept for myself. Then move forward and really make it up.
This should do for now and get me really close!
Yes it’ll work for awhile
They all do until they don’t
Alex Hedrick /
Haha I know you know..
Figured out the dimensions for the third bearing support..
Gunna turn it out of some h13 pre-hardend so it'll be really really tough and easier to turn with a good finish.
Are you gonna make the support adapter slip fit?
That’s what I did.
Alex Hedrick /
> That’s what I did.
Yup.. I want to be able to get it out if need be..
That lip will keep it captive between the bearing and the pulley, its got about .120 gap between the two so figured make it .070 or .080.. it will probably change as I'm turning it, ya know.. lol
Alex Hedrick /
Third bearing support nub all done. Its a nice snug fit all around. Made out of h-13 pre-hardend. Super tough stuff yet not brittle so it should hold up no problem. Still waiting on some gy6 springs to further tune it out.
Alex Hedrick /
I will be gun bluing it so help seal it up.. much more to come!!
If it’s tight in there I would thread it internally to pull it for when you have to remove it. They can get stuck then it sucks to get it out to get the pulley nut off. If I’m not mistaken I think that inner gy6 bore isn’t a straight bore, mine were slightly tapered I think (edited)
Alex Hedrick /
I thought about that, but honestly..I just don't see tapping this material happening.. I think very hard stuff..
I checked and checked mine, its got a straight bore right out at the end where nub slips in. I did have to get in there and de-burr the rough corners from factory machining, after that it snapped right in place..
Giving it a few good spins with the wheel, no binding or anything weird lookin/sounding.. just smoothness!
I dig it...
I bet it’ll be fine
Alex Hedrick /
I was warned!! But ill just keep going.. guess I need that spring retainer thing, plus this is the cheapo spring that came on the pulley, so! Yeah..
I had one on my bike for some time. I litterly put a zip tie in each one of the holes and it held in just fine. But I hated the range it had so I tossed it for a regular one.
Welcome to hell brother
