Re: Motobecane 70cc Airsal Engine Temp
Ian T /
it is actually very common for 70cc kits to push 400F on mobys. even the high performance 50cc kits get hot, but shed heat a lot faster than the 70cc kits. your best bet is to switch to a more tunable carb than the SHA so that you are in optimal fuel/air mix for the entire throttle range. SHA is usually either too lean at the top or too rich at the bottom - always a trade-off
