MPG with a 65cc kit
What mpg are people getting with a 65cc Airsal and race pipe (I have a peugeot but Interested in figures for all peds)
Re: MPG with a 65cc kit
Tweaker trash /
Do the math! Empty your tank, fill it with a 1/4 gallon or whatever And use a gps on your phone to track the miles (edited)
Depends on how much throttle you use and what carb your running. I get around 50-60 mpg but I run a 19mm phbg and do a lot of blasting
Overpriced Parts /
I bet it it’s a bit worse than you think with a 19mm carb
How accurate is the stock vdo Puch odometer? The speedo itself is surprisingly accurate all the way from 0-40 (I ran it against a police roadside speed radar sign and it was exactly dead on at all speeds)
Overpriced Parts /
Depends on what size tire you have but they’re more accurate than every moped speedo that is not vdo, derbi and batavus brands is vdo and way more accurate than CEV other brands most times
If you want the best mpg you would have to study how the jawa mistral was ported. I believe they got 150 mpg and was still able to go 40-50 mph
Friend of mine had a jawa back in the 80s Brand New. We was teenagers then. I had a Vespa Grand did 25-28 mph. He took pipe off jawa it was loud as hell but we didn't Care time's were different obviously. We knew nothing about upgrades. But that jawa would leave the Vespa easily I think it did 40 + never stressed about gas then but it was 70 cent's a gallon.
I’m on a 65cc tomos and get around 45 miles per .6 gallons. Butttt I’m also on a 14:12 carb and intake.
Dirty30 Dillon /
My derbi gets like 50 miles per gallon, tops.
Thanks Garrett. That's what I was after similar kits and an idea of mpg.
I get around 80mpg on a 65cc metrakit, 19mm phbg clone. im usually doing 3/4 throttle around 40mph flat.
Most of my kitted bikes only get about 35 mi to a tank which most of mine are 0.9 gal.
Dirty30 Dillon /
> mine are 0.9 gal.
Yeah, the only exception are my 13.13 vespa, they like to sip
