Have an e50 with a 65cc airsal, matching airsal head, plugged decomp hole, 15 bing, 15mm #1 grandpa intake, metal mesh filter, techno circuit pipe, 14x40 gears and the side covers on the bike.
78 main jet
Needle on 2nd from bottom (1 up from most lean)
Timing and point gap are set to stock specs
3 shoe with ESO springs 1.5 turns in from flush
What speeds should I be seeing with this? Low end is kind of sluggish and I'm topping out around 36mph on the flats? Should I swap out the clutch for a 2 shoe with blue springs for better takeoff?
