E50 65cc Airsal Setup Sluggish?
Have an e50 with a 65cc airsal, matching airsal head, plugged decomp hole, 15 bing, 15mm #1 grandpa intake, metal mesh filter, techno circuit pipe, 14x40 gears and the side covers on the bike.
78 main jet
Needle on 2nd from bottom (1 up from most lean)
Timing and point gap are set to stock specs
3 shoe with ESO springs 1.5 turns in from flush
What speeds should I be seeing with this? Low end is kind of sluggish and I'm topping out around 36mph on the flats? Should I swap out the clutch for a 2 shoe with blue springs for better takeoff?
Re: E50 65cc Airsal Setup Sluggish?
Overpriced Parts /
Is your magneto serviced and are you timed correctly?
I set everything to stock specs. Not getting any hotter than 330 degrees. Also running a b6hs plug. Should I advance / retard my timing? Or is stock preferred with this setup? (edited)
38 mph on that gearing is high 8000s rpm
That pipe falls flat around then. Maybe try a 16 up front?
Worth a shot. I'll try that this weekend
I hit mid 40s with 16/45 which is almost the same gear ratio.
If it's sluggish on low end, definitely change clutch springs to at least blue. You also may be a jet or two rich. Check your plug.
Also, your needle position as you've described is 2nd from most rich, not lean. If the needle is oriented as it sits in the carb, bottom is rich and top is lean. Think of it this way - you pull the throttle and less needle stays down if your clip is at the bottom, which richens your mix.
roots to wings /
trouble tuning mine too. the puch estoril radical side bleed is an amazing pipe. i am messing around with the jetting, timing, airboxes, and air leaks right now, but the best i've had it running so far is 14/40 15mm clone carb, 222 atomizer, 72 jet, stock airbox. takeoff not great, but very good torque and buried the speedo at 40.
trying to follow roffmans spec now, but it's highlighting some other problems in my bike like timing, seals, clutch, and leaks
roots to wings /
curious to hear what you did, because with this exact same setup except the pipe, i realized (with help from MA) that there is no way i can get correct timing without dremeling my stator plate. Can't figure out why the stock plate can't be set to 17 degrees without dremeling. Not even sure I can get past 12 as it sits, which is causing me to run super lean, so much that I can't even get up to higher temperatures past 350 and no power.
roots to wings /
Replaced difficult to tune and leaky clone with used bing 15mm carb (glad to have found one) on kitted bike (65cc airsal) and finally got it dialed in with 14/40 gearing (for now), stock clutch springs (for now), metal mesh filter, 78 jet, 2.17 atomizer, single embossed needle clipped 3 down from top. Estoril radical sidebleed pipe is a game changer. Easily buries speedo at 40. Ken Roff was right...
Dirty30 Dillon /
Why do people even bother with the clones.
