Non shitty express
Alright hear me out i swear I'm not trolling. Single speed express with an e50 jammer clutch swap. The taper matches the og shitty clutch that has no stall so only one thing to do.
Hobbit Metra 47
Doppler pipe
E50 Jammer clutch
21phbg
Maxi forks
Extra cool
Thanks naz for the machining on the clutch bell!
Here's the bike
Here's the clutch bell, e50 bell with an express gear welded on the back of it
Some nice welding on the front
In the bike
On the road again
Waaaay better off the line. Who knew you could make an express kinda sick. need to play with oils to get some nice slip. Does like almost 50 while screaming some high rpms but was shitty off the line because it didn't rev.
That's all I got.
Re: Non shitty express
Oh yeah and since the clutch doesn't have the little kickstart grabby things on it, it's pull start only. Ok bye bye kickstart.
Theoretically, this means KTM clutch on an express is possible if you were to weld an express gear on the back of one of those clutch bells. Thatd be so sick actually. Also, treats only makes a single speed reinforced express crank but that's okay because the two speed clutch would probably blow under this power. Ditch the two speed, always go single speed.
Good job Jose!
I'm impressed, really cool!
