You need to put it in a metal flask, I use soup cans with the top/bottom cut off
Mine were all cracking before I started putting in a flask. Maybe a paint can?
I notmaly used an oven barrel, but the cylinder didn't fit in there thats why I welded the sheet metal thing around it.
But next time its gonna be round.
I’d also recommend using commercial investment powered instead of your plaster mixture. Mix according to instructions.
This should help it hold together better through burnout. Your also not burning out long enough or hot enough. PLA needs approx 1300f (730c)
This is really fun to watch, I really miss casting
The problem with the investment plaster is that I don't get in in germany it is almost impossible. There is basically no one that imports it and if there is one it is to expensive to get.
But if anyone got a suggestion where yo get it it would be appreciated!
I understand this problem well enough. Hit me up in a direct message. The problem is likely a combination of your investment as well as the burnout.
I have not had good results from the commercial investment, waste of money.
I also run like 10% infill, I can't prove it but I think the pla expands a little before it melts and helps crack the plaster.
> burnout.
Also, discuss that shit here! That's what the forum is for, I'm working my way up to a cylinder but I'm getting close
10% infill seems like a good standpoint.
Thats what I am using to and it normally have me good gesults.
So next time a round flask
Yeah the problem I'm having now is that the pla melts and soaks into the plaster. When the molten metal hits it, it outgasses and creates bubbles in the small features.
Have you seen the wax filament yet? It’s a bit expensive but may be what you are looking for
Ehhhh, I don't see any advantage to it, the pla almost burns out better than wax, you are printing it hollow so it's not like doing lost wax where there is a bunch of material to get rid of
Pla burns out quite well. But i have hade the problem withe the pla soaking into the plaster as well. The only work around I found was to burn it out longer.
I have seen the wax filament but I don't think that it would give me an advantage over the pla.
I'm hoping better mold design cures it, I've been trying to pour them from the top but I flipped it now so it's bottom fill and much better vents.
I'm going to try this one more time then I'm buying a vacuum pump and doing vacuum cast.
I have been filling from the bottom to much better result in the end.
You can dissolve PLA with certain industrial solvents. Anything containing Methylene Chloride or Tetra Hydro Furan would work:
Quite nice nice idea with the dissolving.
But I need to burn the mold either way
To fully dry it and covert the plaster.
Yeah I think I have things working pretty well with the burnout right now, it's a good idea but I don't want to add more chemicals into the mix and potential issues.
Looks great!
Also I learned another lesson recently, can't let the mold cool down then heat it again. I had to pause burn out and leave for a few hours, came back and plugged the oven back in and when the plaster heated up again it crumbled.... Try again!
Good Luck Kilian & take your time with the burnout!
I'm considering giving up on lost wax for my cylinder project & going to 100% cope & drag plaster assembly. ¯\_(ツ)_/¯
Why such low timing?
50cc is very limited as far as torque even with decent aux ports and good transfers.
Are you going to run a high rpm pipe on it to get some big revs with low blowdown for a wider band? It’s just a curious way to go for a racer
I love the idea of a wide reaching power band ripper tho
The engine is going to be used in offroad moped racing were most of the winning cylinders are ported polini or athena i forgot zündapp cs25 cylinder which have only a single exaust port. But the ported cylinders often have quite the high exaustport timing. As there are a maximum of 3 gears allowed you need to have quite the wide powerband to have a chance of winning.
I am hoping to achieve that with a large blowdown time area but low timing. The exaust port is extremely wide and shaped for best flow (picture). And yes that limits power, but that isn't terribly important as most other racers have "only" 12hp and with that portlayout and exaustport I am hoping to at least get 14hp but with a exactly as wide or even wider powerband. The pipe is going to be in resonance at quite high rpms somewhere between 12.500 and 13.500 rpm. Also the exaust opening on which the exaust bolts on is an elliptical constriction which helps to keep blowdown velocity high which should also help. Than the constricted ellipse goes over to a normal circular opening.
And also I am not running good transfers I'm running the best transfers, which is an overstatement but they are really good (good controll over the angle of incoming gas because they only bend in one dimension and the layout has ben proven to be very good to (aprillia rsa) There are some duds getting 25hp+ out of that portlayout of corse with higher timing but you get the idea)
I didn’t know it was off-road or I forgot.
Should be great
Is it 20 minutes yet?
I have waited a bit longer to let it cool. But i will open it right now.
Looks great!
Looks great! congratulations!
