Av10 Build Thread: Disco squid
I bought my 50v about 12 years ago when I was 17. Rode stock for about two years and then went to a Parmakit 74cc, a janky circuit pipe, and 16 SHA. At the time I thought I did a ton of other stuff but looking back it wasn't much more than bar and a seat.
It was fun but I didnt really get the Moby thing until this year. I just wanted to make it reliable. So I got a La Party CDI and a Black Gun pipe. A friend of mine saw it and lent me a 21 PHBG. And then a four year relationship ended and I want deeper into the Moby hole than I thought possible. The goal was 60mph; 55 is all I got.
So in the last four months I have done a crank, variator, case matched, head, cdi, pipe, carb, intake, bars, controls, lights, and I have a few parts on the shelf that never made it. Meanwhile me and my friend are talking about making a super ripper. Then I blew out the threads in the Parma. Tried to JB weld the fucker back in and it lasted about 10 miles. So with a long Maine winter ahead it's time to build the bike.
I'm not sure the speed I'm trying to go but fast is the goal. Curently I have some parts in the mail. An Airsal 70cc Water cooled kit. A Polini race case from treats. An airbox from an ausi Kart comapny, and a 28mm intake. I'm hoping to do a PWK 28mm Stage six. not sure the radiator yet but the mizzimoto seems right. Party cdi, er3 vario, ebr fork, wheels, dics, swing arm, shock, basically all of it.
the pictues are:
something from 08
the bike in 2013
beginning of the summer.
Re: Av10 Build Thread: Disco squid
Carb, bars, and a fairing that broke.
Crank, head, and case matching
where it all ended
Sweet. I'm interested, sounds like fun.
You might have them but from the list I'm noticing you don't have a clutch pulley, you will probably want that, also a pullstart maybe and an aftermarket spring if you need it for those cases?
Ya. I honestly just got tired of writing. The er3 I’m running has a clutch function and the stock pulley has been ok. But to do the swing arm I have to pull it so might try to swap out for something nicer. I’m on alibaba right now trying to get a Pull start from Brazil. I think the red dipper is easy to come by but want to look into gas shocks first. Setting up a launch lever will be good. But don’t want it to be necessary, more use it for fun here and there
Its been a while and things are going well. The frame is coming along. I have a friend who can help me weld it up but he's a busy man. So i started thinking about the fork and the seat
Got all my engine stuff in and built that, after case matching the ports.
Then i realized maybe your french bikes don't love you, because you don't love them. And it starting to feel like I'm not building the bike but the bike is building me.
Those brazil pull starts only work on the funky brazilian stator and cases. It's a bummer.
Dude I can’t get anything to work on Alibaba. Shits a no go. I’m going to build one once I get the cdi sorted
Alibaba is set up for bulk orders. Aliexpress is the single item dealio. If it ain't there or the guy doesn't want to deal with a single order deals over....
There's alotta threads on making them here. But honestly dude. Recoil starters are just an over complication. I started my Moby for years with just a strap of leather wrapped around the flywheel.
I certainly understand it when your doing the tuning, but once starting is dialed in a 3ft strip of leather that narrows from an inch to a half an inch worked great for me. I even got fancy and added a wooden dowel after a year or two...
I have to admit that the kick-starts are super sweet when working right.
Good job, Sam. Seen a few silly posts on here, but these pics got a good chuckle out of me. Damn frenchies do need love too
This:
Leads to a house full of these little guys:
Alan Jackson /
hahaha so right rebel.
got frustrated with my paloma as there are no go faster parts and ive had to machine everything (i lie -a pal has) and everyone laughs at me as i ride past??
ive just bought a 50v with av7 motor and totally new to mobylettes so i havent a clue about anything.
ill be watching this thread
ive just bought a bare av10 motor from la france- no lectrics or clutch and ive also bought a parmakit 82cc kit plus cases already matched. 50mm.
that cost more than the bike did.
got hundreds more to spend on crank ignition variator - but got carb and spark plug.
my goal is also 60mph
> as i ride past??
> 50mm.
> spark plug.
Doing the frame work is hard because I need a friends help. Good news is Becky with the good tools let me come by to start cutting stuff up. In Zeros liquid cooled video he mentioned engine mounts ripping off. So we started fabbing up some reinforcements.
I got distracted.
Treats has a MLM swing arm that was out of stock since June. I’ve checked on it so much my phone now autocorrects “mom” to “mlm”. It came into stock and got me fired up again. It’s also seeming that most parts are going to spend a night or two in my bed.
Getting there
Got the wheel spacing sorted. The brakes are next and the seat is just mocked up.
I could write a essay about the amount of tinkering it’s taken to get this far.
Tinkering ... Isn't that the reason you took the project on ? ;)
Looking good , so far .
Maybe consider painting the tire center channels whatever color you make the frame .
Tyler Jaynes /
Nice work! I’m building a race Moby right now and I have a ton of projects for it. It’s not often I see mobys getting any love so it’s always nice to see someone else working on one.
How I’m no scientist. But I feel like covering rubber with paint in the center of the tire seems like a bad idea
Front brake works. Rear brake needs a cable. Rad is hung. And now on to the motor shit.
That same rubber is in contact with the rims full-time.
A stipe in the center groove isn't going to hurt anything .
Heck , some tires come from the factory with some kind of paint or dye in the treads .
