MK 70cc Reed cylinder Puch
Sander Mulder /
Does anybody where i can still get those MK 70cc reed cylinders?, want one for some "Light tuning" ;)
Re: MK 70cc Reed cylinder Puch
> Sander Mulder Wrote:
> https://i.ibb.co/b1Jnfjg/moped-army-2e1611bdf61f07f89de70ab12945710b.jpg
MK reed cylinders, any old links? Ive never heard of these
Sander Mulder /
Dos cycle has them last I checked.
Also, I hope they aren't done for, I plan on blowing a few up
Not the same as the treats reed kit? (edited)
https://www.doscycles.com/products/puch-dos-45mm-70cc-reed-kit?_pos=19&_sid=a7200ff5d&_ss=r&variant=40859899599
nah, this is a clone of Athena clone of the AJH kit... port timing is way off, exhaust port is way too big, its a mess of a kit but i'm working on one with a stroker crank and its gonna be pretty close.
ahhhh yes, the DOS version the port timing isnt so bad, seems like they found a better piston
BUT you had best run it with only one ring (if you use the provided piston) as the rear ring on the piston is like .55555mm away from the intake port, its scary close
I just installed one on my wifes Maxi, cleaned up the ports a little bit, but pretty much slapped it on, with some Malossi reeds, and a MlM VM20 intake/carb combo, paired with a rebuilt e50, Pietcard cdi set up, and carbon baffle Estoril
it rips pretty hard, probably does 45? but its geared for city riding like 14x42 or 14x40 cant remember
yeah i'm gonna build one this winter and try to throw up a big number next summer, its been awhile since i've built anything really fast and i've got that itch... aka i've forgotten how much of a bummer fast mopeds are.
> mopeds are.
They can-a-breaka-you’re-heart
But I feel like if your gonna go fast on a Puch and you aren’t going Polini, this is def the route to take for mega high rpms
If you get the dmp piston port piston and cut a window in it the piston will be ALMOST TDC in the cylinder without having to machine the top of the cylinder. A little porting and hold the fuck on when you're pipe hits! Don't tell anyone though.......
Haha thanks, that's good to know, I still don't understand how you overcome the fact that the bottom of the exhaust is almost 46mm from the top of the cylinder.
I had to order a snap ring bearing but once she comes in I'll install the stroker crank and measure everything.
