Re: Estoril Length- WOW MUCH POWER!!!!!!
Graham Motzing /
The tomos estoril is a totally different pipe, it's got a shorter stepped header and pulls way harder.
The blowdown on the cylinder 'powers' the pipe, essentially you are giving up trapping the energy in the cylinder to push the piston down, and blowing out that energy to get the gasses moving.
The header diameter will determine how efficiently the pipe uses that energy. If you have a small dia header the gasses will keep the velocity high and you don't need as much gas energy to light up the pipe, but it will choke on the top end. If you have a big header it will breathe up top but it will never hit on a cylinder with no blow down.
You can always cut it shorter but you can't cut it longer, so plan on using a radiator hose coupler (yes it will burn up but it's ok for tuning) and cutting the header back until you're happy.
  Estoril Length- WOW MUCH POWER!!!!!!Topic by: . Chudas. . Chudas. 10/17/20 09:12AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Adam Smith Adam Smith 10/17/20 09:39AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Dirty30 Dillon Dirty30 Dillon 10/17/20 09:54AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Probably Fred Probably Fred 10/17/20 11:30AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Born to be WillD Born to be WillD 10/20/20 01:19PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: baird co baird co 10/17/20 12:13PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/17/20 01:19PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Dave Thacker Dave Thacker 10/17/20 04:53PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Dirty30 Dillon Dirty30 Dillon 10/17/20 10:27PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/18/20 01:13AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Daniel '' Daniel '' 10/17/20 05:42PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/17/20 07:18PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/17/20 08:21PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/19/20 08:49AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/18/20 09:18AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/18/20 09:42AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/18/20 09:26AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 01/03/21 11:52AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Jay Rivett Jay Rivett 01/07/21 11:23AM
