> Overpriced Parts Wrote:
> They need to make adjustable length header/chamber pipe so you could
> just squeeze a lever when your rpm is maxed out then move it in closer
> 1-2 inch and then gain 500-1,000 rpm
French bikes got that, sliding header so as it variates you're also changing the header length. raddd
Imagine instead though if you had the port timing change, pulling the exhaust valve open more with RPM
oh yea, they did that too... SICK
