Re: Estoril Length- WOW MUCH POWER!!!!!!
. Chudas. /
Reviving this topic as I saved the header to use on an M101Ks I got from Dos, so after weeks of researching and wrapping my head around variated engines I think I sort of got em figured out.
Hitting 50 mphs with nice acceleration.
Gila Kit, 19 Polini Carb, Polini Variator and Piaggio 100mm pulleys.
I think my limiting factor is I can’t find any more belts of varying length. I have a 444mm and a 451mm, the 451 gets me 4mphs more than the 444.
Now back to the pipe:
I think it’s time to get into it, and as Dillon said the stinger restriction only helps “pack” the pipe; and like Graham said, the blowdown needs to be enough to pack the pipe as well.
The current header on the Tomos estoril is about 22mm and the MLM header is around 25.5mm using basic math I calculated the length required to “match” the volume of both pipes headers.
My fear though unproven is that the Gila kit will not have enough blowdown to reach the wanted results.
Could I theoretically use the stinger restriction to make us for the lack of blowdown of no? I could make the header shorter but I don’t want it to interfere with the stand so I have about 3 inches to work with.
I know that my low end will suffer but I figured I could make up for it by adjusting the clutch and weights.
Thanks dudes, happy new year.
  Estoril Length- WOW MUCH POWER!!!!!!Topic by: . Chudas. . Chudas. 10/17/20 09:12AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Adam Smith Adam Smith 10/17/20 09:39AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Dirty30 Dillon Dirty30 Dillon 10/17/20 09:54AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Overpriced Parts Overpriced Parts 10/17/20 11:30AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Born to be WillD Born to be WillD 10/20/20 01:19PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: baird co baird co 10/17/20 12:13PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/17/20 01:19PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Dave Thacker Dave Thacker 10/17/20 04:53PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Dirty30 Dillon Dirty30 Dillon 10/17/20 10:27PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/18/20 01:13AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Daniel '' Daniel '' 10/17/20 05:42PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/17/20 07:18PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/17/20 08:21PM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/19/20 08:49AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/18/20 09:18AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Graham Motzing Graham Motzing 10/18/20 09:42AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 10/18/20 09:26AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: . Chudas. . Chudas. 01/03/21 11:52AM
  Re: Estoril Length- WOW MUCH POWER!!!!!!Re: Jay Rivett Jay Rivett 01/07/21 11:23AM
