Re: Vespa Tuning/Gearing Q's
Dirty30 Dillon /
If you didn't use a decent fiber gasket for the base, there's a high likelihood you have a leak. Also, despite the indexing collar (which often gets lost on rebuild) the vespa cases can end up very slightly twisted, leaving high spot-voids at the 12/6 position. When you rebuild it's always a good idea to check that the base surface is as close to perfect at the seams, before you install your engine peripherals. It's easily adjusted by loosening the case bolts and some taps with a rubber mallet.
  Vespa Tuning/Gearing Q'sTopic by: Jarod V. Jarod V. 10/18/20 11:22PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 10/19/20 08:42AM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 10/19/20 12:01PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 10/19/20 12:41PM
  Re: Vespa Tuning/Gearing Q'sRe: pat splat pat splat 10/19/20 01:06PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 10/19/20 03:51PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 11/30/20 01:55PM
  Re: Vespa Tuning/Gearing Q'sRe: Jeremy Edwards Jeremy Edwards 11/09/20 05:46PM
  Re: Vespa Tuning/Gearing Q'sRe: pat splat pat splat 11/09/20 05:58PM
  Re: Vespa Tuning/Gearing Q'sRe: EH FCC of the QCB EH FCC of the QCB 11/09/20 08:43PM
  Re: Vespa Tuning/Gearing Q'sRe: Graham Motzing Graham Motzing 11/09/20 08:46PM
  Re: Vespa Tuning/Gearing Q'sRe: Jeremy Edwards Jeremy Edwards 11/10/20 04:12AM
  Re: Vespa Tuning/Gearing Q'sRe: Dirty30 Dillon Dirty30 Dillon 11/10/20 08:31AM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/10/20 09:02PM
  Re: Vespa Tuning/Gearing Q'sRe: todd amundson todd amundson 12/10/20 11:35PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/25/20 04:43PM
  Re: Vespa Tuning/Gearing Q'sRe: Declan g Declan g 12/14/20 10:13AM
  Re: Vespa Tuning/Gearing Q'sRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:52PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/29/20 06:16PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 01/03/21 01:54PM
  Re: Vespa Tuning/Gearing Q'sRe: . Chudas. . Chudas. 01/03/21 02:14PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 01/03/21 03:08PM
  Re: Vespa Tuning/Gearing Q'sRe: Matt Grantonic Matt Grantonic 01/06/21 12:26AM
