Re: Vespa Tuning/Gearing Q's
Jarod V. /
Update: finally took the variator apart, found out the brass bushing the pulley rides on seized, causing it to stay open. I pulled the clutch apart, replaced the pulleys with Treats' aftermarket set with the vented bushing. Replaced the clutch pads with a NOS Piaggio set and replaced the stock contra spring with a yellow Malossi piece. I was tired of dicking with old parts and basically just replaced everything.
Now when I try to put it on the bike it rubs straight on the frame, you can see in the pic where the back of the pulley is wearing a groove into the frame, and this is just from hand spinning the clutch. Apparently these pulleys are slightly different dimensions, am I unable it run these pulleys? Is there supposed to be a spacer or something in between the gearbox and back of the clutch unit to keep it from rubbing?
I've never genuinely hated a moped more than this one lol.
  Vespa Tuning/Gearing Q'sTopic by: Jarod V. Jarod V. 10/18/20 11:22PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 10/19/20 08:42AM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 10/19/20 12:01PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 10/19/20 12:41PM
  Re: Vespa Tuning/Gearing Q'sRe: pat splat pat splat 10/19/20 01:06PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 10/19/20 03:51PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 11/30/20 01:55PM
  Re: Vespa Tuning/Gearing Q'sRe: Jeremy Edwards Jeremy Edwards 11/09/20 05:46PM
  Re: Vespa Tuning/Gearing Q'sRe: pat splat pat splat 11/09/20 05:58PM
  Re: Vespa Tuning/Gearing Q'sRe: EH FCC of the QCB EH FCC of the QCB 11/09/20 08:43PM
  Re: Vespa Tuning/Gearing Q'sRe: Graham Motzing Graham Motzing 11/09/20 08:46PM
  Re: Vespa Tuning/Gearing Q'sRe: Jeremy Edwards Jeremy Edwards 11/10/20 04:12AM
  Re: Vespa Tuning/Gearing Q'sRe: Dirty30 Dillon Dirty30 Dillon 11/10/20 08:31AM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/10/20 09:02PM
  Re: Vespa Tuning/Gearing Q'sRe: todd amundson todd amundson 12/10/20 11:35PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/25/20 04:43PM
  Re: Vespa Tuning/Gearing Q'sRe: Declan g Declan g 12/14/20 10:13AM
  Re: Vespa Tuning/Gearing Q'sRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:52PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/29/20 06:16PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 01/03/21 01:54PM
  Re: Vespa Tuning/Gearing Q'sRe: . Chudas. . Chudas. 01/03/21 02:14PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 01/03/21 03:08PM
  Re: Vespa Tuning/Gearing Q'sRe: Matt Grantonic Matt Grantonic 01/06/21 12:26AM
