Re: Vespa Tuning/Gearing Q's
Jarod V. /
> todd amundson Wrote:
> I shimmed out some 100mm cheeks on a ciao. I made a 13x10x1mm hardened
> washer. Goes on the rear shaft before the variator/clutch assembly goes
> on. 1mm spacing was just right.
> If you can fit the shim down inside the variator it’s easier to install
> than putting it on the shaft first.
I'm having a hard time visualizing what you're talking about, do you have a pic? Are you saying that you put a spacer on the smaller diameter of the output shaft so the clutch assembly bottoms out 1mm further out from the frame?
  Vespa Tuning/Gearing Q'sTopic by: Jarod V. Jarod V. 10/18/20 11:22PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 10/19/20 08:42AM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 10/19/20 12:01PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 10/19/20 12:41PM
  Re: Vespa Tuning/Gearing Q'sRe: pat splat pat splat 10/19/20 01:06PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 10/19/20 03:51PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 11/30/20 01:55PM
  Re: Vespa Tuning/Gearing Q'sRe: Jeremy Edwards Jeremy Edwards 11/09/20 05:46PM
  Re: Vespa Tuning/Gearing Q'sRe: pat splat pat splat 11/09/20 05:58PM
  Re: Vespa Tuning/Gearing Q'sRe: EH FCC of the QCB EH FCC of the QCB 11/09/20 08:43PM
  Re: Vespa Tuning/Gearing Q'sRe: Graham Motzing Graham Motzing 11/09/20 08:46PM
  Re: Vespa Tuning/Gearing Q'sRe: Jeremy Edwards Jeremy Edwards 11/10/20 04:12AM
  Re: Vespa Tuning/Gearing Q'sRe: Dirty30 Dillon Dirty30 Dillon 11/10/20 08:31AM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/10/20 09:02PM
  Re: Vespa Tuning/Gearing Q'sRe: todd amundson todd amundson 12/10/20 11:35PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/25/20 04:43PM
  Re: Vespa Tuning/Gearing Q'sRe: Declan g Declan g 12/14/20 10:13AM
  Re: Vespa Tuning/Gearing Q'sRe: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:52PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 12/29/20 06:16PM
  Re: Vespa Tuning/Gearing Q'sRe: Jarod V. Jarod V. 01/03/21 01:54PM
  Re: Vespa Tuning/Gearing Q'sRe: . Chudas. . Chudas. 01/03/21 02:14PM
  Re: Vespa Tuning/Gearing Q'sRe: - Joe - - Joe - 01/03/21 03:08PM
  Re: Vespa Tuning/Gearing Q'sRe: Matt Grantonic Matt Grantonic 01/06/21 12:26AM
