I have seen several youtube videos about how to make A Tomos 2 speed shift into 2nd at a higher speed. Some mix 90 W gear 50/50 oil with the Automatic Transmission Fluid and put in twice as much of that mixture as recommended while others just put twice as much straight Transmission fluid into the Transmission.
Is there a danger of blowing the seals with the overfilling and have any of you tried this method and if so does it work.
