Treats front disc setup alignment
Terbo Speghetti /
So I've got my treats caliper mounted up on EBRs with the treats bracket. They say it should all line up, but I had to add a 3mm spacer (might still need .3 or .4mm more) between the bracket and the forks.
I haven't set a disc brake up from scratch, but as far as I know, the outer pad (without the piston against it) should be as close as possible to the disc without touching at rest, and the piston side pad should push against the rotor and deflect it a tiny bit into the other pad.
As far as I can tell, there's no way I could move that outer pad 3mm away from the rotor and still be able to brake. Might not even fit in the cutaway on the caliper. It's a pretty tight fit on that side as it is:
So, does anyone else run this setup? Did you have to use spacers like this or am I missing something? (edited)
  Treats front disc setup alignmentTopic by: Terbo Speghetti Terbo Speghetti 11/04/20 09:50AM
  Re: Treats front disc setup alignmentRe: P D P D 11/04/20 09:55AM
  Re: Treats front disc setup alignmentRe: Terbo Speghetti Terbo Speghetti 11/04/20 10:04AM
  Re: Treats front disc setup alignmentRe: EH FCC of the QCB EH FCC of the QCB 11/04/20 12:29PM
  Re: Treats front disc setup alignmentRe: Michael Thomas Michael Thomas 11/04/20 11:00AM
  Re: Treats front disc setup alignmentRe: Terbo Speghetti Terbo Speghetti 11/04/20 11:08AM
  Re: Treats front disc setup alignmentRe: P D P D 11/04/20 11:22AM
  Re: Treats front disc setup alignmentRe: Dirty30 Dillon Dirty30 Dillon 11/04/20 11:12AM
  Re: Treats front disc setup alignmentRe: Mike Boyd Mike Boyd 11/04/20 11:17AM
  Re: Treats front disc setup alignmentRe: Michael Thomas Michael Thomas 11/04/20 01:16PM
  Re: Treats front disc setup alignmentRe: Terbo Speghetti Terbo Speghetti 11/04/20 02:34PM
  Re: Treats front disc setup alignmentRe: Daniel '' Daniel '' 11/04/20 05:54PM
  Re: Treats front disc setup alignmentRe: Graham Motzing Graham Motzing 11/04/20 08:45PM
  Re: Treats front disc setup alignmentRe: pat splat pat splat 11/04/20 05:02PM
  Re: Treats front disc setup alignmentRe: Terbo Speghetti Terbo Speghetti 11/04/20 05:59PM
  Re: Treats front disc setup alignmentRe: Terbo Speghetti Terbo Speghetti 11/04/20 09:19PM
  Re: Treats front disc setup alignmentRe: Alex Fredericksen Alex Fredericksen 11/05/20 04:22PM
  Re: Treats front disc setup alignmentRe: pat splat pat splat 11/09/20 06:06PM
  Re: Treats front disc setup alignmentRe: Ryan Nash Ryan Nash 11/11/20 09:22AM
  Re: Treats front disc setup alignmentRe: Siezed Again Siezed Again 01/11/21 09:25PM
  Re: Treats front disc setup alignmentRe: Siezed Again Siezed Again 01/20/21 08:41PM
  Re: Treats front disc setup alignmentRe: Terbo Speghetti Terbo Speghetti 01/20/21 09:12PM
  Re: Treats front disc setup alignmentRe: Johnny Braaapp Johnny Braaapp 01/20/21 08:50PM
