So there are a few types of ebr - some have flat mount - and others the caliper mounts are staggered. I assume you ordered correctly, and installed the bracket correctly, so maybe it just needs a little more spacing. Your wheel hub width may be coming into play. The Mike Thomas setup is still a time saver. One doesn't have to make the bracket and get the proper alignment of the piston/pads and the rotor surface. Before this kit, I made one from scratch, it took me a few tries.
Re: Treats front disc setup alignment
