I use a cut off wheel on an air grinder and carve a cotter pin groove on the opposite side of one end on the shaft. Much easier than cutting and welding a crank, and you can switch it back if you want.
Then with baby cranks, I have enough ground clearance so they're like pegs, high enough so they don't hit in corners.
