Re: Are dual carb Vespas REAL?
Brian F /
> I wish I could have gotten that case half when it was available, but it
> seems to be no more. I tried on the secondhand market as well. So, the
> pinasco is all I have. . .. requiring me to source or fab a special
> crank.
If you just buy the pinasco case half it comes with a 13mm intake too. The complete dual carb bottom end from them comes with a 19mm intake.
> What other specs will your build have? What kind of vespa?
It's a bravo.
Stock cases + the reed block case half
Kinetic CDI
64cc Polini racing kit
Mazzucchelli crank
Rotary valve intake reamed out to 13mm, 13mm SHA
Reed valve intake w/ malossi 4 petal reed block, 19mm PHBG
Simonini Calibrata exhaust
9.49:1 CIF gear set
Polini variator
MLM water cooled head
Probably a 100mm rear driven pully (I have a pile of rear clutch parts to play with) with a polini spring (edited)
  Are dual carb Vespas REAL?Topic by: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/30/20 03:07PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 11/30/20 03:16PM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 11/30/20 09:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 12:11AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 09:49AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 10:24AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 11:06AM
  Re: Are dual carb Vespas REAL?Re: Dave & Bummerzz Dave & Bummerzz 12/01/20 09:12AM
  Re: Are dual carb Vespas REAL?Re: Edward Koipond Edward Koipond 12/14/20 02:00PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:15PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: discontinuuity _ discontinuuity _ 12/15/20 04:34PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 11:59AM
  Re: Are dual carb Vespas REAL?Re: Tweaker trash Tweaker trash 12/16/20 12:30PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:34PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:37PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:54PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:12PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 01:33PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:36PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 01:04PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/16/20 01:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/17/20 01:36AM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/17/20 09:50AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/17/20 02:34PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:04AM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:28PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 12:35PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/15/20 01:26PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:53PM
  Re: Are dual carb Vespas REAL?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/16/20 12:10AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:58PM
  Re: Are dual carb Vespas REAL?Re: LSLB RXb LSLB RXb 12/18/20 04:08PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 12/20/20 08:33AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 01:10AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:20PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 04:32PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 04:38PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:58PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 06:50PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 05:27PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 07:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 07:36PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 10:52PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/26/20 09:25PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:25AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/26/20 02:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/31/20 03:03PM
  Re: Are dual carb Vespas REAL?Re: Devlin M Devlin M 12/31/20 03:23PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/01/21 06:09PM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 01/06/21 06:03AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:13AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/21/21 12:08PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 01:42PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/21/21 03:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 02:17PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 01/30/21 05:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:34AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/30/21 10:41AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:24AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:35AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:38AM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 01/23/21 02:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 05:08PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 01/29/21 10:56AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/29/21 02:15PM
  Re: Are dual carb Vespas REAL?Re: ian c ian c 01/29/21 09:40PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/29/21 09:51PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:31AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:30AM
