Re: Are dual carb Vespas REAL?
Brian F /
> Superbravo, Moparts aluminum racing subframe, stock cases, Kinetic CDI
> 9.49:1 CIF gear set, Polini variator, and also an MLM watercooled head.
> I've got a lot of wheels to pick from but I'm probably running some cool
> 10 star mags in the back and some 8 (I believe) star rare plastic
> polymer wheels in the front (we'll see if they fit). I like how skinny
> these wheels are.
That's cool, I only have the stock spoked wheels atm. Moparts has been out of stock of the Al subframes, so I'm going to reinforce the stock one (I have the laser cut plate from treats) as an excuse to teach myself how to weld.
> I have yet to find any radiator parts or a pump, etc.
A lot of folks like dirtbike radiators; a radiator from a CR80 is a common choice, they have lots of mounting points, and they're cheap on ebay.
> The air inlet on the rotary side is opened up to 13mm like yours, and
> then like you said the pinasco half is 13mm, I may see about trying to
> open that up a little and potentially run a different intake that sits
> on a slightly different angle. I need to inspect the case half when I
> get it. If I don't modify it I'll run dual SHA carbs probably unless
> that's un-tuneable. I am unsure on pipe right now. Hopefully by the time
> this build comes to fruition Cranks can have his vespa pipe done,
> otherwise I will probably run a calibrata as well or I may modify a huge
> chamber onto a metrakit pipe I have.
I'm going to start by cheating; I'm planning on having two throttles, one for each carb. Idle will be 99% the SHA, and I'll use that for tooting around, then switch over to the PHBG for go-fastness. I'll play with using them both next year, but this will get the bike moving relatively easily. If I find that I hate it all I can always plug up the rotary valve intake and switch to a full circle crank.
> Are you going to thermosiphon with your MLM head? I am opting to run a
> pump first so I don't have to worry as much about flow and cooling while
> tuning, but will probably try to upgrade to a siphon setup in the
> future.
Thermosiphon for sure. Much simpler and they work great on mopeds.
  Are dual carb Vespas REAL?Topic by: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/30/20 03:07PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 11/30/20 03:16PM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 11/30/20 09:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 12:11AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 09:49AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 10:24AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 11:06AM
  Re: Are dual carb Vespas REAL?Re: Dave & Bummerzz Dave & Bummerzz 12/01/20 09:12AM
  Re: Are dual carb Vespas REAL?Re: Edward Koipond Edward Koipond 12/14/20 02:00PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:15PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: discontinuuity _ discontinuuity _ 12/15/20 04:34PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 11:59AM
  Re: Are dual carb Vespas REAL?Re: Tweaker trash Tweaker trash 12/16/20 12:30PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:34PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:37PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:54PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:12PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 01:33PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:36PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 01:04PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/16/20 01:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/17/20 01:36AM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/17/20 09:50AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/17/20 02:34PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:04AM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:28PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 12:35PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/15/20 01:26PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:53PM
  Re: Are dual carb Vespas REAL?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/16/20 12:10AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:58PM
  Re: Are dual carb Vespas REAL?Re: LSLB RXb LSLB RXb 12/18/20 04:08PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 12/20/20 08:33AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 01:10AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:20PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 04:32PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 04:38PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:58PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 06:50PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 05:27PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 07:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 07:36PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 10:52PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/26/20 09:25PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:25AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/26/20 02:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/31/20 03:03PM
  Re: Are dual carb Vespas REAL?Re: Devlin M Devlin M 12/31/20 03:23PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/01/21 06:09PM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 01/06/21 06:03AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:13AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/21/21 12:08PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 01:42PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/21/21 03:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 02:17PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 01/30/21 05:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:34AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/30/21 10:41AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:24AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:35AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:38AM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 01/23/21 02:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 05:08PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 01/29/21 10:56AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/29/21 02:15PM
  Re: Are dual carb Vespas REAL?Re: ian c ian c 01/29/21 09:40PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/29/21 09:51PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:31AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 12:49AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 04/14/21 09:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 09:39AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 04/14/21 09:54AM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 04/18/21 03:38PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 12:55AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 09:54AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 10:03AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 10:30AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 01:00PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 01:06PM
  Re: Are dual carb Vespas REAL?Re: Jax Rhapsody Jax Rhapsody 04/21/21 07:44PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/21/21 07:56PM
