> todd amundson Wrote:
> Funny. Who’s office is that? On the maximum throw comment. Think about
> this. If you have a 15mm and a 19mm carb, the single cable on top will
> only open the 15mm carburetor and the 21 will still have like 5-6mm to
> go but can’t. A one millimeter difference in carburetor bore between the
> two you can get away with but that’s about it.
> The carburetor bores between your two need to be damn near identical.
There is a way around that , but , it would likely require a lever with offset pivot on the larger carb .
I'd imagine tuning would be very interesting .
