I was taking a look at how my XL600 uses the dual carbs on a single cylinder, only one carb has an idle circuit, and at idle the one without is closed off totally. Only once you open up the throttle like maybe 1/4 of the way does the auxiliary carb open up.
Obviously a 600cc single cylinder 4 stroke with 2 carbs is a lot different than this application though
