Re: Are dual carb Vespas REAL?
Jason ( ͡° ͜ʖ ͡°) /
Easiest thing you can do to figure out what?
I think dual intake into the same port is a different situation here performance wise because it's effectively very similar to just adding a bigger carb at that same location. Are you talking about the Y shaped intakes? With 1 set of reeds? I feel like dual carbs on separate intakes in different locations of the crank case, both using different types of induction, is quite different and probably much more challenging to tune.
That throttle cable looks like and uses a very similar mechanism to the one that came with my pinasco kit. The knarps are huge and would need some grinding/modification but I think I may just pick one of those up just in case. Thank you!
  Are dual carb Vespas REAL?Topic by: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/30/20 03:07PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 11/30/20 03:16PM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 11/30/20 09:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 12:11AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 09:49AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 10:24AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 11:06AM
  Re: Are dual carb Vespas REAL?Re: Dave & Bummerzz Dave & Bummerzz 12/01/20 09:12AM
  Re: Are dual carb Vespas REAL?Re: Edward Koipond Edward Koipond 12/14/20 02:00PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:15PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: discontinuuity _ discontinuuity _ 12/15/20 04:34PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 11:59AM
  Re: Are dual carb Vespas REAL?Re: Tweaker trash Tweaker trash 12/16/20 12:30PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:34PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:37PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:54PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:12PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 01:33PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:36PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 01:04PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/16/20 01:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/17/20 01:36AM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/17/20 09:50AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/17/20 02:34PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:04AM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:28PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 12:35PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/15/20 01:26PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:53PM
  Re: Are dual carb Vespas REAL?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/16/20 12:10AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:58PM
  Re: Are dual carb Vespas REAL?Re: LSLB RXb LSLB RXb 12/18/20 04:08PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 12/20/20 08:33AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 01:10AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:20PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 04:32PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 04:38PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:58PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 06:50PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 05:27PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 07:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 07:36PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 10:52PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/26/20 09:25PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:25AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/26/20 02:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/31/20 03:03PM
  Re: Are dual carb Vespas REAL?Re: Devlin M Devlin M 12/31/20 03:23PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/01/21 06:09PM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 01/06/21 06:03AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:13AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/21/21 12:08PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 01:42PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/21/21 03:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 02:17PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 01/30/21 05:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:34AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/30/21 10:41AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:24AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:35AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:38AM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 01/23/21 02:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 05:08PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 01/29/21 10:56AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/29/21 02:15PM
  Re: Are dual carb Vespas REAL?Re: ian c ian c 01/29/21 09:40PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/29/21 09:51PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:31AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 12:49AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 04/14/21 09:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 09:39AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 04/14/21 09:54AM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 04/18/21 03:38PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 12:55AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 09:54AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 10:03AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 10:30AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 01:00PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 01:06PM
  Re: Are dual carb Vespas REAL?Re: Jax Rhapsody Jax Rhapsody 04/21/21 07:44PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/21/21 07:56PM
