What I don’t understand is why you wouldn’t want control over each carb individually.
Snordly ran a double carb setup with individual throttle control on an e50 during pinball with a 16mm case reed and 24mm piston port. So fucking fast.
I guess I’m just lost on why people don’t mod Vespa cases for big reeds. I know there’s not much room but surely there’s enough to cram a 24mm ID aluminum tube into the cases and weld it in somewhere, then use a separate stand alone reed block
