You still using the intake pad for duration right? It’s a small area I get it but doesn’t the walls around the window increase the charge sealing area? This the closest one I’ve seen?Dude the charge has plenty of area going through one web and dissipating before hitting the wall 10mm away. My big reed ciao has a charge hitting a solid full circle web head on. Not ideal but still shreds.
Re: Are dual carb Vespas REAL?
