Re: Are dual carb Vespas REAL?
Jason ( ͡° ͜ʖ ͡°) /
> todd amundson Wrote:
> You still using the intake pad for duration right? It’s a small area I
> get it but doesn’t the walls around the window increase the charge
> sealing area? This the closest one I’ve seen?Dude the charge has plenty
> of area going through one web and dissipating before hitting the wall
> 10mm away. My big reed ciao has a charge hitting a solid full circle web
> head on. Not ideal but still shreds.
Oh hell yeah I know it's gonna rip! But it's still less than ideal for it to shoot into the other half of the crank web but it's like the only way to do it I guess.
Yes, rotary intake is for my 1st carb. I've done intake patches this wide on multiple vespas and they RIP, no issues sealing. Generally I was told by others as long as you leave 1-2mm of material around the edge you will be fine with sealing. The width of the sealing edges is only half of the battle though as the web of the crank needs to sit between .25mm and .35mm away from the sealing surface. And with the variation is production of both stock and aftermarket cranks that often isn't the case.
I'm not done with that intake patch modification though. As it sits now the right and left, opening and closing, edges are too rounded and oval shaped. I need to make them more square so that the patch opens and closes much more abruptly and the intake pulse is a lot stronger. (edited)
  Are dual carb Vespas REAL?Topic by: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 11/30/20 03:07PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 11/30/20 03:16PM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 11/30/20 09:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 12:11AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 09:49AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/01/20 10:24AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 12/01/20 11:06AM
  Re: Are dual carb Vespas REAL?Re: Dave & Bummerzz Dave & Bummerzz 12/01/20 09:12AM
  Re: Are dual carb Vespas REAL?Re: Edward Koipond Edward Koipond 12/14/20 02:00PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:15PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: discontinuuity _ discontinuuity _ 12/15/20 04:34PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 11:59AM
  Re: Are dual carb Vespas REAL?Re: Tweaker trash Tweaker trash 12/16/20 12:30PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:34PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/16/20 12:37PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:54PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:12PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 01:33PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/16/20 01:36PM
  Re: Are dual carb Vespas REAL?Re: Nick MBC Nick MBC 12/16/20 01:04PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/16/20 01:37PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/17/20 01:36AM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/17/20 09:50AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/17/20 02:34PM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 12/16/20 12:04AM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/15/20 12:22PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/15/20 12:28PM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/15/20 12:35PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/15/20 01:26PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:53PM
  Re: Are dual carb Vespas REAL?Re: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 12/16/20 12:10AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/15/20 11:58PM
  Re: Are dual carb Vespas REAL?Re: LSLB RXb LSLB RXb 12/18/20 04:08PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 12/20/20 08:33AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 01:10AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:20PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 04:32PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 04:38PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 12/24/20 04:58PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 12/24/20 05:22PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 06:50PM
  Re: Are dual carb Vespas REAL?Re: P D P D 12/24/20 05:27PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 07:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/24/20 07:36PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 12/24/20 10:52PM
  Re: Are dual carb Vespas REAL?Re: Graham Motzing Graham Motzing 12/26/20 09:25PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/26/20 02:25AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 12/26/20 02:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 12/31/20 03:03PM
  Re: Are dual carb Vespas REAL?Re: Devlin M Devlin M 12/31/20 03:23PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/01/21 06:09PM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 01/06/21 06:03AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:13AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/21/21 12:08PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 01:42PM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/21/21 03:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 02:17PM
  Re: Are dual carb Vespas REAL?Re: pat splat pat splat 01/30/21 05:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:34AM
  Re: Are dual carb Vespas REAL?Re: EH FCC of the QCB EH FCC of the QCB 01/30/21 10:41AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:24AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:35AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/21/21 11:38AM
  Re: Are dual carb Vespas REAL?Re: JBOT Admin JBOT Admin 01/23/21 02:24PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/23/21 05:08PM
  Re: Are dual carb Vespas REAL?Re: todd amundson todd amundson 01/29/21 10:56AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 01/29/21 02:15PM
  Re: Are dual carb Vespas REAL?Re: ian c ian c 01/29/21 09:40PM
  Re: Are dual carb Vespas REAL?Re: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 01/29/21 09:51PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 10:31AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 01/30/21 11:30AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 12:49AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 04/14/21 09:29AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 09:39AM
  Re: Are dual carb Vespas REAL?Re: Dirty30 Dillon Dirty30 Dillon 04/14/21 09:54AM
  Re: Are dual carb Vespas REAL?Re: Frederick vdL Frederick vdL 04/18/21 03:38PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 12:55AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 09:54AM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 10:03AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 10:30AM
  Re: Are dual carb Vespas REAL?Re: Brian F Brian F 04/14/21 01:00PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/14/21 01:06PM
  Re: Are dual carb Vespas REAL?Re: Jax Rhapsody Jax Rhapsody 04/21/21 07:44PM
  Re: Are dual carb Vespas REAL?Re: Jason ( ͡° ͜ʖ ͡°) Jason ( ͡° ͜ʖ ͡°) 04/21/21 07:56PM
