Help needed with headlight wiring!
is anyone familiar with the tun'r aftermarket headlight from treatland? I'm trying to get the low and high beam wires correct. The headlight came with 3 wires. Black-ground yellow,=green. I'm wanting to know if anyone knows which is low and high between a green or yellow? Thanks
Re: Help needed with headlight wiring!
Doesn't matter wire it up. If high is low and low is high just reverse it
Tuner lights! Be careful your in the performance forum
Well the lights not performing well so there's only this one and repair.
You can check it if you have a 6 volt battery charger. Hook neg up to neg, then touch the positive to each wire.
Don't use a 12v charger on 6v lights unless you want to blow them out.
Unless I'm mistaken that's a 12v headlight
Then you can check it with a 12v charger.
I don't know the voltage for that particular light. I was just saying how to check.
I have an old charger that you can switch from 6-12, and i check old lights, horns, etc.
I used that one on my kymko like 200! Great headlight for a scooter missing a headlight!
got yah Aaron. was kinda easy. was a lame question! apologize
yes I love the tun'r carbon fiber headlight from treats. it's the best halogen headlight so far that I've used. it was a good buy.
https://sfbay.craigslist.org/eby/mcy/d/concord-2015-yamaha-r3/7235068677.html
This guy likes it too! For sure not stolen
Tweaker trash /
We know that’s ur bike
