Vespa 108mm pulley cheecks
Chris Carleton /
This on a Boxer. Loving it but belt is kinda noisy slapping metal on subframe. Gonna try a piece of teflon under bottom of belt should work will see if there's friction between rubber and teflon. Anyone doing or done this?
Re: Vespa 108mm pulley cheecks
Dirty30 Dillon /
You gotta do something, you're going to start frying belts like that.
Also, I rode that bike as a single speed and I totally would have just left it SS and rocked it. Ye Olde Classique Boxer
Chris Carleton /
No harm done as it is a big heavy bike and I'd rather not have vehicles crawling up my ass in traffic.
todd amundson /
Dude that’s sick. Won’t happen on a ciao. All I could fit was the 100mm.
The frame structure would be gone after all the cutting. What about bending the fuck out of it? Does that work?
Chris Carleton /
So you weld then its possible. I modded a Ciao to accept the 108mm pulleys. Pics to follow.
Have you ridden that clutch yet? I was curious how those scooter clutch arms worked out.
todd amundson /
It’s bonkers how well it works. The issue if it all is because I don’t have the trailing end of the arm digging into the bell first, the stall speeds higher. A setup where the trailing edge digs in first, like stock pads or starter shoes required more spring. The lightest spring I could find was a stock grande spring. It’s so nice starting with the weakest springs and working your way up. I have yet to go up though. I was going to flip shoes and make another clutch but it works so well as is it would be a huge waste of another stock clutch for experimenting.
