Re: Vespa 108mm pulley cheecks
todd amundson /
It’s bonkers how well it works. The issue if it all is because I don’t have the trailing end of the arm digging into the bell first, the stall speeds higher. A setup where the trailing edge digs in first, like stock pads or starter shoes required more spring. The lightest spring I could find was a stock grande spring. It’s so nice starting with the weakest springs and working your way up. I have yet to go up though. I was going to flip shoes and make another clutch but it works so well as is it would be a huge waste of another stock clutch for experimenting.
