Re: first av10 build
Justin Caswell /
So my hand was a bit forced (enabled) today when i was torquing the flywheel nut and it stopped getting tighter but just kept spinning before even making 30 ft lbs. Its holding good enough to get the other things set up properly (brakes etc) but i am reasonably sure the threads on the crank finally shit themselves (steel treats nut)
SO i took the opportunity to order
treats budget racing crank with new seals and bearings
av7 gaskets
Airsal 45mm 70cc kit
aluminum 70cc head gasket (metal fiber one in the kit looks iffy at a glance)
variator roller guide with adjustable weights
and a voltage regulator
Will get some pics up when i start pulling things apart if anyone cares. Hoping the ports match up enough that i dont have to mess with the port timing and can just get away with some light case matching/smoothing
Can i get away with a stock modded blunderbus for this? or would i benefit from an expansion chamber pipe?
Should re-title the thread "another av7 kit" (edited)
  first av10 buildTopic by: Justin Caswell Justin Caswell 12/22/20 06:28PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/23/20 12:52PM
  Re: first av10 buildRe: Rebel Moby Rebel Moby 12/24/20 09:36PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 05:34PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/26/20 09:23PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/27/20 08:13AM
  Re: first av10 buildRe: Rebel Moby Rebel Moby 12/27/20 01:15PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/27/20 11:00PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/28/20 08:10AM
  Re: first av10 buildRe: rick ziereis rick ziereis 12/25/20 06:01PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 06:15PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 06:42PM
  Re: first av10 buildRe: Jean Pondemer Jean Pondemer 12/31/20 05:33AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/01/21 04:53PM
  Re: first av10 buildRe: Jarod V. Jarod V. 12/25/20 08:30PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 11:51PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/28/20 06:11PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/29/20 09:47AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/29/20 10:59AM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/29/20 12:00PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/29/20 12:09PM
  Re: first av10 buildRe: Rebel Moby Rebel Moby 12/29/20 02:24PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/29/20 06:57PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/04/21 10:43PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/04/21 10:57PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/03/21 06:14PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/03/21 09:45PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/03/21 10:36PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/04/21 06:53PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/04/21 08:57PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/04/21 09:24PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/07/21 05:16PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/10/21 06:24PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/11/21 03:02PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/11/21 05:45PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/12/21 12:59AM
  Re: first av10 buildRe: Tweaker trash Tweaker trash 01/12/21 03:05AM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/12/21 10:27AM
  Re: first av10 buildRe: EH FCC of the QCB EH FCC of the QCB 01/12/21 08:00AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/13/21 02:27AM
  Re: first av10 buildRe: EH FCC of the QCB EH FCC of the QCB 01/13/21 08:18AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/01/21 07:56PM
  Re: first av10 buildRe: Tweaker trash Tweaker trash 03/01/21 09:56PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/04/21 05:12PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/09/21 05:13PM
  Re: first av10 buildRe: P D P D 03/09/21 05:43PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/09/21 06:30PM
  Re: first av10 buildRe: P D P D 03/09/21 07:38PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/13/21 03:32PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/31/21 03:48PM
