Re: first av10 build
Justin Caswell /
yeah i was going to soak the head in oven cleaner then drop it in an ultrasonic as long as theres no rubber seals on the stem of the decomp, before lapping it in. curious to see if ill need to do any work on the squish band, or if the stock head will match up well enough. I did some reading in the tuners handbook, and a friend has a lathe and mill in his garage. We were both machinists for a brief time so i think we can get ourselves into some trouble.
If the piston matches up to the stock head well enough without any weird clearance issues i will just leave it as is to lower the C/R a hair and hopefully mitigate the heat issues.
  first av10 buildTopic by: Justin Caswell Justin Caswell 12/22/20 06:28PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/23/20 12:52PM
  Re: first av10 buildRe: Rebel Moby Rebel Moby 12/24/20 09:36PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 05:34PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/26/20 09:23PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/27/20 08:13AM
  Re: first av10 buildRe: Rebel Moby Rebel Moby 12/27/20 01:15PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/27/20 11:00PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/28/20 08:10AM
  Re: first av10 buildRe: rick ziereis rick ziereis 12/25/20 06:01PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 06:15PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 06:42PM
  Re: first av10 buildRe: Jean Pondemer Jean Pondemer 12/31/20 05:33AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/01/21 04:53PM
  Re: first av10 buildRe: Jarod V. Jarod V. 12/25/20 08:30PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/25/20 11:51PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/28/20 06:11PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/29/20 09:47AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/29/20 10:59AM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 12/29/20 12:00PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/29/20 12:09PM
  Re: first av10 buildRe: Rebel Moby Rebel Moby 12/29/20 02:24PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 12/29/20 06:57PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/04/21 10:43PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/04/21 10:57PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/03/21 06:14PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/03/21 09:45PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/03/21 10:36PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/04/21 06:53PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/04/21 08:57PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/04/21 09:24PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/07/21 05:16PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/10/21 06:24PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/11/21 03:02PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/11/21 05:45PM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/12/21 12:59AM
  Re: first av10 buildRe: Tweaker trash Tweaker trash 01/12/21 03:05AM
  Re: first av10 buildRe: Graham Motzing Graham Motzing 01/12/21 10:27AM
  Re: first av10 buildRe: EH FCC of the QCB EH FCC of the QCB 01/12/21 08:00AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 01/13/21 02:27AM
  Re: first av10 buildRe: EH FCC of the QCB EH FCC of the QCB 01/13/21 08:18AM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/01/21 07:56PM
  Re: first av10 buildRe: Tweaker trash Tweaker trash 03/01/21 09:56PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/04/21 05:12PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/09/21 05:13PM
  Re: first av10 buildRe: P D P D 03/09/21 05:43PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/09/21 06:30PM
  Re: first av10 buildRe: P D P D 03/09/21 07:38PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/13/21 03:32PM
  Re: first av10 buildRe: Justin Caswell Justin Caswell 03/31/21 03:48PM
