Re: Kitting Tomos A3
Overpriced Parts /
> Jay Rivett Wrote:
> I agree with everything except the oil in your transmission. I have
> been out of the tomos game for a bit, but I believe you want to only run
> an ATF in your tranny.
No most A3 engine clutches are different then a A35 as the clutch lining material is asbestos not junky cork so you can use synthetic motor oil for good results,
But the problem with a3’s is they are geared extremely low, lower then a a35 and have brass con rod small end bushings not needle bearings like a a35/a55 so pushing high rpm with power ruins the crank bushing so you’re getting 2 bad things on a A3 over a a35 so kitting any Tomos engine you can still have issues,
You’re better off in the long run just stock modifying it by just putting an upgrade carburetor, exhaust and gear on, maybe a little porting and calling it a day,
I did/do that with every Tomos I had, ran them for many miles then sold them still running with nothing busted,
  Kitting Tomos A3Topic by: Thomas Peffer Thomas Peffer 12/26/20 03:22PM
  Re: Kitting Tomos A3Re: P D P D 12/26/20 04:31PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/26/20 04:44PM
  Re: Kitting Tomos A3Re: P D P D 12/26/20 05:20PM
  Re: Kitting Tomos A3Re: Jay Rivett Jay Rivett 12/27/20 11:39AM
  Re: Kitting Tomos A3Re: Overpriced Parts Overpriced Parts 12/27/20 10:32PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/27/20 10:41PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/27/20 11:02PM
  Re: Kitting Tomos A3Re: Matt Mulligan Matt Mulligan 12/27/20 11:25PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/29/20 10:33PM
  Re: Kitting Tomos A3Re: Matt Mulligan Matt Mulligan 12/29/20 10:49PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/29/20 11:07PM
  Re: Kitting Tomos A3Re: Matt Mulligan Matt Mulligan 12/30/20 02:32AM
  Re: Kitting Tomos A3Re: ♣Slew Foot♣ ♣Slew Foot♣ 12/27/20 07:01PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/27/20 09:50PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/27/20 10:01PM
  Re: Kitting Tomos A3Re: Kevin Bishop Kevin Bishop 12/30/20 10:55AM
  Re: Kitting Tomos A3Re: pat splat pat splat 12/30/20 11:10AM
  Re: Kitting Tomos A3Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 12/30/20 01:53PM
  Re: Kitting Tomos A3Re: Dirty30 Dillon Dirty30 Dillon 12/30/20 02:04PM
  Re: Kitting Tomos A3Re: Graham Motzing Graham Motzing 12/30/20 02:18PM
  Re: Kitting Tomos A3Re: Dirty30 Dillon Dirty30 Dillon 12/30/20 02:27PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/30/20 07:23PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/31/20 05:58PM
  Re: Kitting Tomos A3Re: P D P D 12/31/20 06:06PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 12/31/20 06:18PM
  Re: Kitting Tomos A3Re: P D P D 12/31/20 06:50PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 01/03/21 11:00AM
  Re: Kitting Tomos A3Re: Chris Temple Chris Temple 02/08/21 05:19AM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 02/08/21 08:31PM
  Re: Kitting Tomos A3Re: Thomas Peffer Thomas Peffer 02/08/21 08:42PM
