> pat splat Wrote:
> Well, if you are really hitting 38mph on a stock tomos w no porting and just bolt ons thats pretty darn good
> Anyone telling you otherwise is BS, reading their stock speedo, not verifying with a gps or weigh 10 lbs.
> Do you use a timing gun?Consult timing in wiki.
> I am guessing some has changed out 2nd gear spring already since it shifts at 20 instead of the stock 10 or so.
> Are you running an air filter? air filters affect jetting quite a bit on sha carbs, running a stock unmodded box filter changes jetting.
>A good speed is when my helmet starts to lift from the wind speed hitting my little sun visor and starts lifting the whole helmet up.
Just bolt on, no porting yet. I guess that’s my next step there.
No timing gun, just trial and error atm.
Stock gear springs, 1st and 2nd (got the bike basically new). I noticed it holding first longer after the reeds and head went on
Figured there might be some fibbing going on with the top speeds
Small aftermarket air box (drilled out) with velocity stack incorporated and panty hose filter material (pictured below). I was running just the velocity stack but it seemed the air box gave it more consistency and back pressure
And that’s funny about the helmet, I judge the same way 🤣🤣 (edited)
