Re: Custom pipe experience? Cut Weld Hack Benelli G2 / A35 Pipe
JBOT Admin /
And don’t burn thru, it’s super easy to do if you’re doing mig or flux core. I do many small tacks first then weld over them, or if I run a bead from the start I run a low power setting in order to not punch holes. But the multiple tacks works good to stop punching thru the pipe
