If you press bearings into some mag hubs, some will not have a lip that the bearing od can seat into. That’s kinda shitty because then the bearing can float inside the hub and the wheel can actually walk to one side.. so the solution is to make an OD spacer (even if you use loctite)
There was a lip way down in the hub, so I added a od spacer that took up that room, and adapted it to be the same distance as the inner spacer. Wheel cannot walk to one side now.
